IK thanks , I was able to download the B version of PDF , but did not find the A vs.
My friend has at least 3 of these CV ovens , one display went out a couple yrs ago , I found a defect with the pins at the right angle bend coming out of the display tube , a bunch were cracked , so I soldered wires overlaying the pins and that fixed that one .
Now a couple yrs late the other went dead , looked for the same issue and not an issue .
One of the black diodes had what looked like the solder heated up and looked questionable , so going to remove to make sure testing is leaving out any other circuit results , then resolder to see if it works - I like to solve observable questions before looking for deeper issues .
I tried to find a wiring diagram / schematic to fallow it through , but they say they will not let it out .
Will check your suggestions .
Digi-key local here , or at least in state , there online quote was $145.49 , the local sales guy for Noritake [ the one that hand delivered a couple of free samples { different ;( } quoted $175.16 ] .
I get free BBQ for partial payment and also get to learn more on repair , so I feel like get paid a couple of times , Kansas City style BBQ .
Thanks , will give result later .
