Hi!
I got hold of a non fuctioning 5 years old Epson EB-1925W projector. When pressing power on, after few seconds the fans started to blow at full speed and 3 red leds started flashing. That is an internal error according to the manual. So i ordered a new ballast board from China. After i changed the ballast everything worked fine for a few hours. Then it started to turn off the lamp after 3 minutes or so and blink the leds again. Yesterday i watched two full length movies with no problems, today it won't light up at all. The lamp is an original spare with only 200 hours in the counter. There is no dust anywhere and all the fans work fine. Could the Chinese ballast been faulty or is there some other fault that could cause this behavior or make ballast boards burn?
Seppo
