Well....not having much luck. It's not easy trying to get to the back side of the interface board.
Still no -8V. I followed procedures to isolate the CRT circuit. No luck. Then isolate the horiz. amp. No luck. Replaced all the electrolytics, and a lot of the tantalums. No luck. Checked all the rest of the tantalums: all check good.
Removed the bridge rectifier (CR1561). It tests good. However, with the rectifier in the circuit, I only get +3V AC from the transformer. Can't see any way to disconnect the bridge in order to retest the secondary winding.
All other voltages check O.K. When I move the intensity knob back and forth, I get a blip on the screen.
I'm now officially lost.
