Author Topic: new vacuum tube boxes  (Read 1457 times)
Offline graybeardTopic starter
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« on: March 05, 2022, 08:08:31 am »
My Tektronix 575 died a week ago and I am testing the tubes.   I found a few very weak ones that need replacement.   However when I look at my stock of tubes they are a disorganized mess.  I need to get some boxes to store them better and make a spreadsheet as I box them.
Where is the best place to buy new boxes for vacuum tubes?
Thanks
Chris
Online CatalinaWOW
Re: new vacuum tube boxes
« Reply #1 on: March 05, 2022, 11:13:13 am »
Places like Uline will have small boxes that are not a perfect fit for your tubes, and will happily make custom sized boxes.  Prices  and minimum orders are discouraging.
I make my own from cereal boxes.  When really motivated I print the outsides, usually by printing the desired material on white paper and gluing that onto the cardboard with spray adhesive.
It is a bit tedious, but in a weekend you could have a tub of tubes boxed.
Online Ian.M
« Reply #2 on: March 05, 2022, 11:47:05 am »
Thin card can easily be laser cut.  If you've got access to a laser cutter, and use roll-on permanent glue tape and a wooden block jig for each size for assembly, you could easily make all the boxes you need in a couple of hours, including inserts to cradle the base of non-straight sided tubes.
Offline TimFox
« Reply #3 on: March 05, 2022, 04:31:38 pm »
Antique Electronic Supply has white tube boxes.
https://www.tubesandmore.com/products/tube_accessories
The following users thanked this post: jpanhalt
Offline BrokenYugo
« Reply #4 on: March 05, 2022, 04:44:36 pm »
I would be looking for larger boxes with dividers, especially for the smaller tubes.
    • Chris Grossman
« Reply #5 on: March 05, 2022, 06:09:39 pm »
I found these vacuum tube boxes at Tube Depot.  They seem to be the best source I can find.  However I am still open to suggestions.
