Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Radeon 7950 voltage issues
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Radeon 7950 voltage issues (Read 1647 times)
nano21
Newbie
Country:
on:
February 13, 2018, 04:53:39 pm »
Hi all,
I have a problem with the 7950, voltage on the right side of the card on the mosfet is 0.1v (smaller vrm on the left of the gpu is ok). I did found Core channel on youtube helpful but hi did have 0.9v so its not the same problem. I dont see any physically damaged components on the board. Capacitors closer to the 6pin connectors (before mosfet) are measuring 12v. I have very very limited electronics skill but if somebody can point me in the right direction I can replace components on the board as I have access to the hot air station. I think its maybe the ic labeled CHiL because all gpu phases measure 0.1v or maybe its some kind of short somewhere?
PSU is 750w from a workstation with two 6pin (as needed for the card) and thats not an issue. I also tried both bios, also booted win on the integrated graphics - 7950 is not recognized in the device manager.
Logged
KhronX
Frequent Contributor
Country:
Re: Radeon 7950 voltage issues
Reply #1 on:
February 14, 2018, 12:48:13 am »
Can you measure the ohms between the VRM output and ground? With the power off, of course.
Logged
Khron's Cave
- Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
nano21
Newbie
Country:
Reply #2 on:
February 14, 2018, 12:26:14 pm »
Gpu vrm measures 0.6-0.7omhs, all six the same, but vram phase (left, closer to pink caps) measure 9.8ohms and one on the right I can`t even measure in the same range... When I changed multimeter to 20k range then measured 3.55.
Logged
KhronX
Country:
Reply #3 on:
February 14, 2018, 03:42:50 pm »
"Of course" all six measure the same - their outputs are all in parallel.
That being said, 0.6-0.7 ohms is a liiiitle bit (too) low, so there's a certain chance the GPU itself is bye-bye
Logged
Khron's Cave
nano21
Newbie
Country:
Reply #4 on:
February 14, 2018, 04:06:17 pm »
Similar readings as mine
https://youtu.be/fuuRg9M-QTA?t=42s
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
