Hi, I'm working on an RFL 750 Gaussmeter. It is the early version with the battery compartment at the rear of the unit. When I power it up with AC supply selected I get no meter indication at all even when twiddling the pots on the front panel. I checked the power supply, it is a simple zener regulated supply at 19VDC and that checks good. Also checked the meter movement and it is also good. I need a schematic to figure out whats going on! Also wonder what batteries it used. There are three holders for cylindrical batteries in series and my guess that the batteries would be 6 volt units but can't what vintage battery was used.
Cheers,
Corby
