CRT monitors have a model number, chassis number, CRT number, serial number, manufacturer's name.
You'd have to find the chassis number for any luck in finding the schematic. That would be somewhere on the main board as a sticker or pcb silkscreen, check both sides. I can't see much from the fuzzy pics.
Or search for the game's name i.e. Zaxxon to find the monitor's schematic in that service manual.
Orion CRT sticker is M34JZT20X is I think 34cm CRT, not the monitor's model number.
The 500 reference designators are likely the horizontal output section.
You'll have to stare at the board and look for the root chassis number.
