Author Topic: Trying to troubleshoot a main board with Rockchip RK3288 microprocessor  (Read 8674 times)
Online Nominal Animal
Re: Trying to troubleshoot a main board with Rockchip RK3288 microprocessor
« Reply #25 on: January 19, 2022, 10:17:15 am »
I emailed AKAI support to get a fix but no possibility to get any software assistance, just send the unit back on my own cost then they will have a look to fix it.
Yeah; sorry if I sounded too angry there, but this is the case with way too many Linux-based appliances.  Way too many routers for example are vulnerable to attacks and are easily subverted to become a part of a botnet –– but not because Linux is inherently vulnerable or needs to be constant updates to stay secure, but more because most of the software that implements the appliance is just so full of security holes it is ridiculous.  To me, it is like seeing someone smear shit on the walls and laugh.
Also, to be clear: Tux is my mascot, not my idol; and I'm not a GPL zealot.  I use a lot of different licenses, including CC-1.0 for my code examples, proprietary licenses for commercial work, BSD/MIT/Apache for some libraries, and GPL only when doing either already-GPL-licensed stuff or when I deem it the most appropriate for the product at hand.  License is just one of the tools for me.  Seeing others misuse them is like seeing people try to hammer screws in.
[    1.812699] dwc2 ff540000.usb: DWC OTG Controller
[    1.812714] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[    1.812851] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    1.812857] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.812861] usb usb1: Product: DWC OTG Controller
[    1.812864] usb usb1: Manufacturer: Linux 5.4.115-inmusic-2021-04-30-rt56 dwc2_hsotg
[    1.812867] usb usb1: SerialNumber: ff540000.usb
[    1.813152] hub 1-0:1.0: USB hub found
[    1.813174] hub 1-0:1.0: 1 port detected
That means usb1 is the USB On-The-Go port, using a DesignWare chip (not the USB5537), and works fine.  (In other words, the On-The-Go port should work fine.)
[    1.935665] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[    1.935773] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    1.935778] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.935782] usb usb2: Product: DWC OTG Controller
[    1.935785] usb usb2: Manufacturer: Linux 5.4.115-inmusic-2021-04-30-rt56 dwc2_hsotg
[    1.935788] usb usb2: SerialNumber: ff580000.usb
[    1.936093] hub 2-0:1.0: USB hub found
[    1.936113] hub 2-0:1.0: 1 port detected
Funky; it has two USB On-The-Go ports!  Both should be working just fine.
Bus 003 Device 001: ID 1d6b:0002
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 0763:0016
Bus 002 Device 001: ID 1d6b:0002
Now, this one is very useful.  From the above, we already know that Bus 001 Device 001 and Bus 002 Device 001 are USB On-The-Go ports using the standard kernel dwc2 driver (for DesignWare high-speed On-The-Go USB controllers); it looks like there is even a third one, heh –– which makes sense, actually; parts cost and whatnot.
(1d6b:0002 just means generic USB 2.0 root hub; the 1d6b identifier is "Linux Foundation".)
There is only one USB device connected, and that is to the first on-the-go bus: ID 0736:0016 0763:0016.
0736 is the Manufacturer ID for M-Audio, but its product 0016 is not listed in the Linux USB device ID list.
Could you run lsusb -vvv (as root on the device), and copy the part that begins with Bus 001 Device 002: ID 0763:0016 until an empty line?  It would provide all information the kernel knows about the device.  I am especially interested in the 'bDeviceClass', which I suspect to be '9 Hub', and this device be the actual USB5537B hub chip.  (If so, it means the actual chip is not fully busted at least, because the chip that it is connected to still enumerates it just fine; it would be a very strong indicator that the issue is crappy code in usb5537.c that cannot deal with the normal age-related variances in system behaviour.  Typical for thrown-together low-quality code!)
« Last Edit: January 19, 2022, 10:22:46 am by Nominal Animal »
Offline ounsatn
« Reply #26 on: January 20, 2022, 08:09:07 am »
Hello, I a new on this forum i was googling for MPC and find your post.
On my side I own a MPC Akai Force with a customm Firmware allowing to connect on the SSH.
All theses boards (Headrush Gigboard / Denon Prime or Akai MPC Live/Force share the same SOC with RK3288 .
You can find useful information on this github :
https://github.com/TheKikGen
To connect via SSH instead of using serial cable, you can follow this guide :
https://github.com/TheKikGen/MPC-LiveXplore/wiki/Enabling-SSH-on-the-MPC-Live-X-one-Force
It should be the same way on the Headrush.
Concerning the img file provided :
You have a first .img which is packed, extract it with 7zip  and you'll get another image file which approx 300/400 mb.
You can still open it with 7zip and extract the content.
You will find more information there too :
https://github.com/TheKikGen/MPC-LiveXplore/wiki/How-to-extract-the-2.6-rootfs-img-from-the-update.img
You can explore the file and find useful information.
Scripts allow to configure the board, and Evil is the main program for the Gigboard.
you can try to run it mannualy ( cd /usr/Evil , then ./Evil )
To restore your board, did you try to press the "recover" switch on the board ? Normally when you press it and start the board, this one switches to a special mode which allow you to restore a firmware on a USB Stick.
The request was not for me but fyi here is my full lsusb -vvv
# lsusb -vvv
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            5.04
  iManufacturer           3 Linux 5.4.130-inmusic-2021-07-08-rt59 dwc2_hsotg
  iProduct                2 DWC OTG Controller
  iSerial                 1 ff580000.usb
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0008
    Ganged power switching
    Per-port overcurrent protection
    TT think time 8 FS bits
  bPwrOn2PwrGood        1 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0000
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x0001
  Self Powered
Bus 002 Device 003: ID 09e8:0040 AKAI  Professional M.I. Corp. Akai Pro Force
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x09e8 AKAI  Professional M.I. Corp.
  idProduct          0x0040
  bcdDevice            0.43
  iManufacturer           1 Akai Pro
  iProduct                2 Akai Pro Force
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0078
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      iInterface              0
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               1.00
        wTotalLength       0x0009
        bInCollection           1
        baInterfaceNr(0)        1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceSubClass      3 MIDI Streaming
      iInterface              0
      MIDIStreaming Interface Descriptor:
        bLength                 7
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength       0x0054
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (MIDI_IN_JACK)
        bJackType               1 Embedded
        bJackID                 1
        iJack                   6 (error)
        bLength                 6
        bDescriptorType        36
        bJackID                 2
        iJack                   7 (error)
        bLength                 6
        bDescriptorType        36
        bJackID                 3
        iJack                   8 (error)
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (MIDI_OUT_JACK)
        bJackID                 4
        bNrInputPins            1
        baSourceID( 0)          1
        BaSourcePin( 0)         1
        iJack                  22 (error)
        bLength                 9
        bDescriptorType        36
        bJackID                 5
        bNrInputPins            1
        baSourceID( 0)          2
        BaSourcePin( 0)         1
        iJack                  23 (error)
        bLength                 9
        bDescriptorType        36
        bJackID                 6
        bNrInputPins            1
        baSourceID( 0)          3
        BaSourcePin( 0)         1
        iJack                  24 (error)
        bLength                 9
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
        bRefresh                0
        bSynchAddress           0
        MIDIStreaming Endpoint Descriptor:
          bLength                 7
          bDescriptorType        37
          bDescriptorSubtype      1 (GENERAL)
          bNumEmbMIDIJack         3
          baAssocJackID( 0)       1
          baAssocJackID( 1)       2
          baAssocJackID( 2)       3
        bLength                 9
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bNumEmbMIDIJack         3
          baAssocJackID( 0)       4
          baAssocJackID( 1)       5
          baAssocJackID( 2)       6
  Self Powered
Bus 002 Device 006: ID 09e8:703b AKAI  Professional M.I. Corp. Card Reader
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idProduct          0x703b
  bcdDevice            8.28
  iManufacturer           3 Akai MPC
  iProduct                4 Card Reader
  iSerial                 5 000000000014
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0020
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x002a
  bNumDeviceCaps          3
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000f0e
      BESL Link Power Management (LPM) Supported
    BESL value     3840 us
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x00
    wSpeedsSupported   0x000e
      Device can operate at Full Speed (12Mbps)
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   1
      Lowest fully-functional device speed is Full Speed (12Mbps)
    bU1DevExitLat          10 micro seconds
    bU2DevExitLat        2047 micro seconds
  Container ID Device Capability:
    bLength                20
    bDescriptorType        16
    bDevCapabilityType      4
    bReserved               0
    ContainerID             {8cf6c06a-4a90-f138-a5b1-4f6856b8ed90}
Device Status:     0x0000
  (Bus Powered)
Bus 002 Device 005: ID 13e0:2517 TSE Inc. USB Mass Storage Device
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x13e0
  idProduct          0x2517
  bcdDevice            1.00
  iManufacturer           1 TSE Inc.
  iProduct                4 USB Mass Storage Device
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0020
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceSubClass      5 SFF-8070i
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  (Bus Powered)
Bus 002 Device 004: ID 13e0:2515 TSE Inc. USB Embedded Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  idVendor           0x13e0
  idProduct          0x2515
  bcdDevice            1.00
  iProduct                3 USB Embedded Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0022
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
        ** UNRECOGNIZED:  09 29 01 0d 00 32 64 02 ff
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x000d
    Per-port power switching
    Compound device
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubContrCurrent    100 milli Ampere
  DeviceRemovable    0x02
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  Self Powered
Bus 002 Device 002: ID 09e8:5040 AKAI  Professional M.I. Corp. Force Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idProduct          0x5040
  bcdDevice           50.00
  iManufacturer           1 Akai Professional
  iProduct                2 Force Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0029
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             7
    Compound device
  DeviceRemovable    0xe0
 Hub Port Status:
   Port 2: 0000.0100 power
   Port 3: 0000.0503 highspeed power enable connect
   Port 4: 0000.0100 power
   Port 5: 0000.0103 power enable connect
   Port 6: 0000.0100 power
   Port 7: 0000.0100 power
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x002a
  bNumDeviceCaps          3
    bLength                 7
    bDescriptorType        16
    bmAttributes   0x00000002
      HIRD Link Power Management (LPM) Supported
    bLength                10
    bDescriptorType        16
    bmAttributes         0x00
    bU2DevExitLat         231 micro seconds
    bLength                20
    bDescriptorType        16
    bReserved               0
    ContainerID             {63736d73-7835-7878-0000-002c11095b74}
  Self Powered
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  bcdDevice            5.04
  iManufacturer           3 Linux 5.4.130-inmusic-2021-07-08-rt59 ehci_hcd
  iProduct                2 EHCI Host Controller
  iSerial                 1 ff500000.usb
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0009
  bPwrOn2PwrGood       10 * 2 milli seconds
 Hub Port Status:
  Self Powered
It can be different on yours, because it's possible to forge usb devices with Linux Gadget modules ( google it ofr more details)
Good luck  :) :)
« Last Edit: January 20, 2022, 08:13:17 am by ounsatn »
« Reply #27 on: January 20, 2022, 10:31:42 am »
Here is what the lsusb -vvv describes about the USB bus topology on that board (although order within each vertical segment is unspecified):
RK3288
 ├─ Bus 001 Device 001: USB 2.0 hub based on a DesignWare On-The-Go chip, uses standard Linux kernel driver
 │  (no connected devices)
 └─ Bus 002 Device 001: USB 2.0 hub based on a DesignWare On-The-Go chip, uses standard Linux kernel driver
     └─ Bus 002 Device 002 (09e8:5040): AKAI Professional M.I. Corp. Force Hub
         ├─ Bus 002 Device 006 (09e8:703b): AKAI Professional M.I. Corp. Card Reader
         ├─ (not connected to any device)
         ├─ Bus 002 Device 004 (13e0:2515): TSE Inc. USB Embedded Hub
         │   └─ Bus 002 Device 005 (13e0:2517): TSE Inc. USB Mass Storage Device
         ├─ Bus 002 Device 003 (09e8:0040): AKAI Professional M.I. Corp. Akai Pro Force
         └─ (not connected to any device)
The DesignWare chips are ubiquitous, and basically handle the On-The-Go functionality (fifth pin in USB micro connectors, telling whether this end should be the device or the host; the Linux side can use that to make the port either a host or a device using USB gadget drivers); very commonly used on SBCs where one or more ports can act as both host and device.  This board has only two of them.
Bus 001 Device 001 is the first On-The-Go USB "hub", with just one port.  That port is not currently connected to anything.
Bus 002 Device 002 is the second On-The-Go USB "hub", with just one port.  It is connected to an AKAI-branded USB hub (Bus 002 Device 003), which is not listed in the Linux USB IDs list.  I also cannot find the USB product number (5040 in hexadecimal, 20544 in decimal) anywhere in Linux USB hub drivers, so it looks like this hub also uses some proprietary driver that Akai is breaking the GPL license and copyright law with.  Naughty, naughty.  It does say it has seven USB ports, three of which are in use (first, third, and fifth), with the first two in high speed mode (480 Mbit/s), and the third in full speed mode (12 Mbit/s).  Which one is which is my educated guess; the hierarchy is fully described under /sys/bus/usb/ but it isn't important enough to worry about here.
Bus 002 Device 003 is the full-speed device (09e8:0040) connected to aforementioned Akai USB hub, and is a MIDI controller based on its endpoints: three MIDI IN jacks, and three MIDI OUT jacks, and a couple of general (control) endpoints.  Basically a simple USB-MIDI interface, in other words.  (USB ID not listed in Linux USB IDs list, so who knows what driver this uses.)
Bus 002 Device 006 is a high-speed device (09e8:703b) connected to aforementioned Akai USB hub, and is a card reader.  Again, USB ID not listed in Linux USB IDs list, so who knows what driver this one uses.
Bus 002 Device 004 is a yet another hub, this time one manufactured by TSE Inc.  It has only one port, which is connected to Bus 002 Device 005, an USB mass storage device also made by TSE Inc.  I do believe these two are either connected or even on the same actual chip, with the hub part controlling the power delivery and upstream connectivity, and the mass storage device being a standard USB mass storage device (Flash storage, perhaps eMMC, perhaps something else) using standard Linux USB mass storage drivers.  The USB ID, 13e0:2517, has been seen on old 1 GB USB sticks ("Flashdrive 1GB").
What does this tell us about these devices?
  • The topology is indeed one where at least one of the DWC OTG ports is connected to a "nonstandard" multi-port USB hub, like I suspected.
    In this particular device the hub is 09e8:5040, whereas jboy32 has 0763:0016.  These numbers are unlikely to be spoofed, as they are usually provided by the USB hub itself, i.e. its own internal firmware.
  • The storage on this device is based on an existing USB storage chip seen on 1GB USB sticks.
    These devices do not have particularly good wear leveling, so depending on how the filesystem has been configured and mounted, might wear out.
  • Akai uses USB hub drivers not in official Linux sources, and seems to use other USB devices they use their own USB manufacturer ID for, too.
    This means that they have a custom Linux kernel tree to support those devices.
    Not providing those sources for their customers is a violation of the GPL license.  Because violating that license means they do not have a license permitting them to distribute the Linux kernel as part of their device, they are breaking international copyright law and agreements.
Naughty Akai, naughty.
The funny thing here is that the driver code really isn't something you want or need to keep "secret".  Akai wins absolutely nothing, and actually loses a lot (of experience and help from volunteers like myself who habitually fix bugs just as a hobby for example), by hiding the kernel sources.  Only the crappy developers who they commissioned the drivers from benefit from keeping the sources hidden, as that way their crappiness is kept hidden, and not derided in public.  I wish somebody would hit them with a copyright lawsuit, just to whack the Akai ossified officers with a clue bat.
Note that there is nothing wrong in keeping the userspace code (the user interface et cetera) proprietary; that's theirs.  But the kernel is not.
« Reply #28 on: January 20, 2022, 10:34:07 am »
If you do want the actual tree, use lsusb -t (as root) to display the physical USB hierarchy as a tree.
Both of these, lsusb -t and lsusb -vvv are useful, but they do need to be listed separately.  (That is, lsusb -t -vvv won't work.)
Offline ounsatn
« Reply #29 on: April 22, 2022, 01:11:20 pm »
Hello,
Very interesting, i will do the command again soon because there is a sort of mux switch and when you change a certain value in a file, it will disconnect midi interfaces and allow the board to become a slave and to be seen as an usb drive when connected on a computer ( On these products : Akai/headrush/Denonprime, it's called " computer mode" ).
The cons is when we are in computer mode , all the midi controller ( buttons , controls , fader etc ..) are disabled or inactive.
(I am a bit deriving form the original subject  :-// ).
Another thing i saw is that you can use usb gadget to forge fake devices, it seems to be used on these boards.
I'll post more details about later :)
Offline domas.zelionis
  • Country: ie
« Reply #30 on: April 24, 2022, 01:44:26 pm »
Hey,i am also trying to fix some issues on my Denon Prime4, as it is out of waranty and ticket with support did not bring me to resolution....anyway, its uses exactly the same motherboard. but the issue i currently facnig is that debug port only outputs data, it does not allow me to interrupt a boot or use login prompt after its boots....so just wondering did you needed to do anything special to get that working ?
as on u-boot i see input says
"In:    gpio-keys"
and only for out and err i have:
"Out:   serial,
 Err:   serial"
so just wonder is that same on your one and did input worked out of the box or you need to do something special to make it work ?
Thanks
Best regards,
Domas Zelionis
Offline Castor troy
« Reply #31 on: August 14, 2023, 11:33:43 am »
Hi everyone
My board is in a headrush gigboard.
The debug port have 6 pins but none are spotted.
Someone could heplp me please?
Offline tbegal
6 Pin Serial Port Connection
« Last Edit: June 03, 2024, 06:45:23 am by tbegal »
Offline carlitzt
Hello everyone,
I know this threat is old, but do own a Headrush Pedalboard that also has the USB problem, so the device is not visible on my computer (nor Windows , nor Mac).
After reading the messages, I do have a question:
I am not an linux user, so I can not follow the output.
I studied electrical engineering, so I am good at hardware.
Would a solution be, to use one of the other usb ports of the board, to connect them to the computer?
Is the problem more a hardware type (usb driver chip is faulty) or is it more a software issue (new firmware update had a bug and disables usb transfer function)?
Any suggestions here?
