Author Topic: Onkyo A9711  (Read 1382 times)
Offline EugeniacTopic starter
Onkyo A9711
« on: December 28, 2016, 10:45:57 am »
Hi every boby,i ha ve a problem with a Onkyo a9711. in fact, afriend give it to me for repair the right channel with the power transistor blown. i change that devices but the short remain until disconnect the
P503 connector between driver and power amp.board.somebody have an idea of what happens?
thanks in advance.
Offline mzacharias
Re: Onkyo A9711
« Reply #1 on: December 28, 2016, 05:28:16 pm »
Are the mica insulators installed between the new output transistors and the heat sink?
