Yes, I saw that the EEPROM values can be changed to enable these options. The EEPROM is a XICOR X2816CP-20 and it can be had for a few dollars on Ebay. I was however hoping that I would not have to desolder, buy EEPROM programmer and adapter, read out, tweak, reprogram, solder in DIP socket etc. when the instrument has the software update feature via the front panel entry. If I'm not able to get my hands on the proper option 010 unlock code, I may have to go down that route though.
On the other hand, if the 010 option was lost due to the EEPROM having lost some bits, it may be a good idea to read out its content and store for safe keeping.
Thanks,
/John.
