The MM was in a position when I took the picture but it's the same for all positions AC, DC , ohm ...
I checked the rotary switch there is no missing contacts. I tested also the rotary switch from my 187 and same result.
I think the Asic is bad, I cannot imagine these issues coming from side components.
