Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
HP 3312A Repair (Bad Switch Contacts)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: HP 3312A Repair (Bad Switch Contacts) (Read 1205 times)
Jackson
Contributor
Country:
on:
May 22, 2018, 11:21:01 pm »
Hello all,
I'm currently working through a back log of teardowns/repairs I'm working on (and have finished). This one is a successful repair from a couple months ago, an instrument I obtained over the winter (along with several others) from a Craigslist deal. The function generator worked well except for the range switches (see video below). It seemed to be stuck on a certain range. Looking at the schematic (attached) and seeing the way the range switches were all laddered together, I went about testing them all when pressed/unpressed for continuity. Sure enough, the 1 MHz and 100 kHz range switches both showed spotty continuity. A bit of Deoxit and some actuation later and the thing was as good as new!
https://youtu.be/JVX2LxFuFkQ
Logged
Jackson
Contributor
Country:
Re: HP 3312A Repair (Bad Switch Contacts)
Reply #1 on:
May 22, 2018, 11:24:48 pm »
And for followup, here are some general images of the insides that I took when I had it apart. Nice and tidy inside. Unseen in the top of the last picture is the bottom row of BNC connectors and dials, which are obscured by the metal frame.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
