Hello
Thais topic is being created, because i am an idiot.
I bought 3 used , non tested lcd projectors. No bulb, no refuns, 10$ a piece. All of the projectors that used AC lamps, i was able to test and evaluate that they would work, and one of them, the worst looking one is now the only one i fully fixed.
I couldn't test the one that useds DC lamp, no bulb of this kind to hack it. But projector had the best oprics, so i bought replacement lamp, cheap chinese one but still should be a dc one. the lamp arrived and still no sign of life. if the ballast was working it should strike if even only once but no.
there is no known place to find a schematic for the balast and i have no idea how to trubbleshoot it to be certain it isn't the bulb that would be a problem. no way of thesting the bulb in other projector either, all of the othe projectors use AC lamps
Fun part is, all the other sanyo projectors i have, use the same chinese model of ballast and they all work, and the only one that use rubycon branded ballast does not
is there a way to safely measure how does ballast work. Strike voltage and stuff. Stucking multimeter probes doesn't seem to be the best idea, and i don't have a high voltage probe for the scope (i could build resistor devider, this should work with dc output even if the bandwidth be a mess)
most of components are very small smd stuff, ballast comunicate with the projector via some kind of smart serial bus, so at least i know that the brain is somewhat responsive, without the balast communication cable projector auto shootdown with a red light, with it connected it do normal startup cycle with 3 ignition try and then shootdown
all the mosfets and big diodes are ok, at least component tester recognize them as correct kind of component
I could try to draw a schematic starting from datasheet for dc converter used in it, but i already tryed to read smd component values and most of them look unreadable.
Projector in question Sanyo plc-xw57
ballast board
Rubycon prd 7491ea based on 2SK3869 and 2sk2699 mosfets and m51995ap driver chip
oryginal lamp should be a dc Shp117 but i have no more info about the bulb itself
Can something like that be even trubbleshooted without a schematic?
by the way, new ballast bard cost about 90$ on aliexpress but now i am afraid the something else might be broken, so i am not going to buy one
