Author Topic: Need full firmware (full dump flash) oscilloscope Atten ADS 1062CML  (Read 26517 times)
Offline routerfan
  • Country: cn
Re: Need full firmware (full dump flash) oscilloscope Atten ADS 1062CML
« Reply #25 on: April 27, 2020, 01:53:50 pm »
Thanks tv84! Download and test now!
Offline routerfan
  • Country: cn
« Reply #26 on: April 27, 2020, 02:15:25 pm »
Unfortunately, no success!
ATTEN_ADS1000CAL_V100R003B01D01P31R16_ProdId_79.ADS  CRC32 D13B5706
« Last Edit: April 27, 2020, 02:21:14 pm by routerfan »
Offline tv84
  • Country: pt
« Reply #27 on: April 27, 2020, 02:27:31 pm »
 |O
It's referring to the "Product Type" which is SDS1102CNL !
I changed the "Product ID" of the FW.
SHow me what is the response to these SCPI comands:
MD5_CMPY?
MD5_PR?
MD5_SRLN?
Offline routerfan
  • Country: cn
« Reply #28 on: April 27, 2020, 02:34:25 pm »
The level is limited, I have to see how to get the SCPI interface :-BROKE
Offline tv84
  • Country: pt
« Reply #29 on: April 27, 2020, 03:40:44 pm »
routerfan,
Try flashing this file (through the upgrade method).
If it succeeds, it will change the "Product Type" of your scope to "ADS1102CAL".    I hope...   Then you can flash my previous .ADS.
If it doesn't succeed, don't blame me!  :)
This file was done specifically for you since your are able to recover the flash via programmer, I think you should be able to recover if anything goes wrong.
Edit: remove the file. You can use the Atten official one, in one of the next messages.
« Last Edit: April 30, 2020, 09:27:38 pm by tv84 »
The following users thanked this post: routerfan, alexitaly
Offline alexitaly
« Reply #30 on: April 27, 2020, 05:50:31 pm »
|O
MD5_CMPY?
MD5_PR?
MD5_SRLN?
wait please... i will try as soon as possible! THANKS!!!
routerfan,
I've tried both the version with product_id = 79 and the version with product_id = 80
« Last Edit: April 27, 2020, 06:02:42 pm by alexitaly »
Offline tv84
  • Country: pt
« Reply #31 on: April 27, 2020, 06:09:15 pm »
Alex,
You upgraded with the .cfg also?
Show me the results of those SCPI commands.
So, you still can't upgrade with the Atten firmware, right?
The following users thanked this post: alexitaly
Offline alexitaly
« Reply #32 on: April 27, 2020, 06:26:32 pm »
YES
OK please wait i've to connect the old pc
YES, i can't upgrade  :'(
Offline alexitaly
« Reply #33 on: April 27, 2020, 10:47:57 pm »
During the driver's installation: as you can see the oscilloscope appears as SDS110X.
I am thinking that this is a form of signature and that it is necessary to replace some wording such as "ADS ..." with "SDS110X" in the ATTEN firmware. What do you think about?
« Last Edit: April 28, 2020, 11:02:45 am by alexitaly »
Offline routerfan
  • Country: cn
« Reply #34 on: April 28, 2020, 01:30:49 am »
   Thank you tv84, I will try to use this CFG file to upgrade the configuration after work, and will also try to install Easysysope and use SCPI commands.
 You are right, I can try boldly, because I can recover any file through the programmer, thank you again for your efforts! :clap: :-+
« Reply #35 on: April 28, 2020, 01:50:21 am »
Be sure to install EasyScopeX correctly and before connecting the DSO to the PC otherwise Windows can install a generic USB driver and it won't work ! Then you will need to edit/replace the USB driver in Device Manager.
The correct USB connectivity drivers come within the NIVISA Runtime package that needs to be installed alongside EasyScopeX.
Offline alexitaly
« Reply #36 on: April 28, 2020, 10:56:18 am »
Hi routerfan, what is the programmer that you are using? And how do you connect it to the mainboard? Have you the pinout of the programming connectors on board?
Thanks!
Offline routerfan
  • Country: cn
« Reply #37 on: April 28, 2020, 12:09:36 pm »
I successfully connected to the SCPI command interface, but I have not started to refresh the CFG file :-DMM
Offline routerfan
  • Country: cn
« Reply #38 on: April 28, 2020, 12:18:57 pm »
My programmer is xeltek SUPERPRO / 500, but all I get is a motherboard, I assembled it。As you can see, I purchased an adapter for burning
Offline routerfan
  • Country: cn
« Reply #39 on: April 28, 2020, 12:47:12 pm »
Let me talk about the good news first, Siglent_CAL.cfg does not make my oscilloscope brick :box:. Siglent_CAL.cfg changed my device type, it is now 1102cal, but the fw of upgrading atten still prompts "Product type does not match", SCPI command interface has been unable to connect . Then I tried to downgrade to ATTEN 1102CAL through the USB port, the file I used was ATTEN_ADS1000CAL_V100R003B01D01P31R16, and then the machine suggested that Product type does not match, as before. I will try to use other files. Thanks TV84 :scared:
I'm thinking about whether SCPI has hidden martial arts secrets, maybe it can help solve my problem >:D
« Last Edit: April 28, 2020, 01:47:58 pm by routerfan »
Offline alexitaly
« Reply #40 on: April 28, 2020, 01:52:16 pm »
Hi, today I can't write: I had a small injury and I have to go to the hospital. Se you soon.
Offline routerfan
  • Country: cn
« Reply #41 on: April 28, 2020, 02:03:07 pm »
I am sorry for that,I wish you recover soon!
Offline tv84
  • Country: pt
« Reply #42 on: April 28, 2020, 04:29:33 pm »
Routerfan,
Can you make dumps through JTAG?
It would help a lot if we could see the difference in the dumps of the changes we make.
So, now, we've been successful in changing the Product ID of the FW and the Product Type that appears in the scope's screen.
Both changes are useless but, at least, we know they work... :)
We need to discover what needs to be changed. I'll try to have another look.
From both of you it would help if you were able to dump via JTAG!
Offline tv84
  • Country: pt
« Reply #43 on: April 28, 2020, 05:58:45 pm »
Here is the official .CFG file of Atten CAL scopes.  This will place back all Atten settings, including the splash screen.
Let's try this one.
Offline alexitaly
« Reply #44 on: April 28, 2020, 08:24:11 pm »
Let's try this one.
I'm back, luckily nothing serious.
I've installed your .cfg file and, as you said, almost all the ATTEN settings have been restored. In my opinion, there is a digital signature somewhere: in fact, the scope is viewed as "SDS110X" from the pc, as you can see.
After updating to the ATTEN .cfg file, the bug in trace update in slow time/base settings is not resolved. I'm wondering: is this bug related to the SIGLENT version of fw or not? I'm thinking that also other scope models (rebranding) with only 40k memory have this bug, but i can't know their hw version: have they old CYCLONE III / SAT7.820.681H board?
Can the actually installed SIGLENT fw check this (supposed) digital signature of the old ATTEN fw and block the update?
Thanks.
« Last Edit: April 28, 2020, 08:36:11 pm by alexitaly »
Offline routerfan
  • Country: cn
« Reply #45 on: April 29, 2020, 12:23:28 am »
Yes, I can dumps through JTAG, I am talking about hardware. But I don't quite have the skills in this area, so I need some basic guidance. And I do n’t have JTAG pins installed on my oscilloscope, if I want to do this I have to install them,This will take some time, thank you, TV84!
« Last Edit: April 29, 2020, 12:25:03 am by routerfan »
Offline tv84
  • Country: pt
« Reply #46 on: April 29, 2020, 09:21:18 am »
Take your time and do a mem dump through JTAG. I wont be able to help as I never dumped a BF but there are some guides here in those threads that you previously quoted (from other guys).
With the mem dump probably we can advance further.
Offline routerfan
  • Country: cn
« Reply #47 on: April 29, 2020, 11:49:36 am »
I will try to learn, it should not be very difficult. I will come here to follow the new progress after the dump is completed, thanks again!
Offline alexitaly
« Reply #48 on: April 29, 2020, 08:19:57 pm »
Tell me the responses to the SCPI commands.
I'm trying and i've little driver problems. Excuse me, please wait...
And try again to flash the Atten FW (ID 79 and 80).
I've tried yesterday both Atten FW: the result is the same... Product type does not match as you can see
« Reply #49 on: April 29, 2020, 08:32:40 pm »
With EasyScopeX ?
Please see attached tips for correcting them.
