Author Topic: To solder and desolder a very small things  (Read 787 times)
Offline abdulbadiiTopic starter
« on: September 11, 2021, 05:16:31 pm »
Would you share your golden tricks to be able masterly solder and desolder a very small pins (holes) tightly laid in a narrow PCB ?
« Last Edit: September 13, 2021, 02:13:19 am by abdulbadii »
Offline David Hess
  • DavidH
Re: To solder and desolder a very small things
« Reply #1 on: September 11, 2021, 10:14:33 pm »
My first trick is lots of Kester 1544 or equivalent rosin flux brushed on.
Online DaJMasta
    • medpants.com
« Reply #2 on: September 13, 2021, 12:08:49 am »
You're probably going to have to be more specific for particular applications, but some options to look into:
Hot air gun with a narrow nozzle
Tweezers with a bend
Inspection optics (magnifier, microscope, etc)
Good gel flux (at least for me)
Fine solder
Kapton tape to protect adjacent parts
Holder for the PCB
Sometimes even a preheater can help you get in and apply less heat from the topside to narrow spaces.
The following users thanked this post: abdulbadii
