I managed to connect a Lipo battery for direct charging -against common sense and probably some manuals-
Even more, I realized I had the polarity reversed after hearing the loud pop and the magic smoke smell.
Upon inspection before fixing this little unit, I found two things that called my attention:
First, the casualty was D1 (the largest diode visible at the bottom right, below the current sense spring wire). It had blown into pieces.
Mi question is, how much protection is there after the diode has blown and the circuit gets open? I could not find the schematics for this board to check the protection circuit.
Second, I am pretty sure that the silkscreen for that diode shows a reverse orientation, showing the cathode to the left side!!
. Am I missing anything? I'm just glad I double checked against pictures on the internet before soldering the replacement diode. Otherwise I would have soldered it wrong.
