Author Topic: Looking for a 3.3V LDO regulator with different pinout  (Read 553 times)
Offline maxmadTopic starter
  • Country: gr
« on: August 06, 2023, 05:19:55 pm »
hello,
I am looking for a SOT-23-5 or SOT-25 3.3V LDO regulator.
The original one has been blown and there are no marks except for a 3V3.
Every similar LDO I have searched has no identical pinout.
The majority have Pin 1 as Input and Pin 5 as Output. Those two pins are connected at the PCB so such a pinout is not acceptable.
Looking for an LDO with a pinout like this:
Pins 1-5 --->  Vin - Enable  (Shorted)
Pin 2 -----> Ground
Pin 3 -----> Capacitor to ground
Pin 4 -----> Vout
Right now I dont want to make any modification to use another LDO.
So i am looking for the right one.
Offline fzabkar
« Last Edit: August 06, 2023, 05:42:57 pm by fzabkar »
The following users thanked this post: maxmad
Offline DavidAlfa
Re: Looking for a 3.3V LDO regulator with different pinout
« Reply #2 on: August 06, 2023, 06:54:07 pm »
NJM2888F
« Last Edit: August 07, 2023, 03:03:51 am by DavidAlfa »
  • Country: gr
« Reply #3 on: August 06, 2023, 08:03:17 pm »
TAR5S33 seems exactly the same!
RT9193-33 more mA but wrong pinout...
NJM2888F  is also good!
Thanks all!
Offline DavidAlfa
« Reply #4 on: August 07, 2023, 03:05:03 am »
Oops, sorry, my copy & paste failed, the RT chip was from a previous search... I actually meant NJM2888F.
