First off - my apologies for dredging this up, but I really want to add some pertinent info to an otherwise very informative thread.
Oh, and as for the comments about "cooking" chips with a 450*C heat gun - those guns are barely hot enough to cook dinner, let alone a GPU. I regularly assemble SMD boards using standard Sn63/Pb37 solder, and 450*C is almost the
exact temperature I use. I can set the gun to 800*F and blast the fresh SnPb paste until the cows come home, but it's not going to melt. 850*F is where I like to be. I even go as high as 900*F for smaller parts (0805, SOD-123, etc.). I use a large expansion (NOT reduction!) nozzle btw. Without the nozzle, the temp would probably have to be >1,000*F for lead-free solder, and that's approaching the limit of the gun.
If anyone wants to figure out the exact heat-gun conversion ratio, just pour a small amount of distilled water into a test tube, and try to boil it. Common sense will have you start with temps near ~220*F, but you'll quickly realize that 220*F is not even hot enough to burn your hand. In order to make the water boil, you'll have to get the gun to around 400*F. Since water boils at 207*F in my area (Los Angeles), that means the conversion factor is about 2:1. In other words, to create a 420*F reflow profile, you'll have to set the gun to 420*2 = 840*F.
So that's the first thing. More to the point of the thread, I want to explain that I've figured out the (actual) permanent fix for GPU issues. I've been using my Vaio laptop all day everyday for the past 10 years, and during that time, I've had to reflow the GPU about 10 times. It was after that tenth time that I finally discovered the real fix. That was 18 months ago, and since then, my laptop has worked better than it did when it was new. Here's what I did:
1. Reflow the GPU. I won't tell you how, since you already know. I will say that I didn't have my "good" Steinel heat gun at the time, so I had to use a cheap Harbor Freight gun. After a very, very long thermal soak period, I put the heat on "high" and held it point-blank against the GPU for 28 seconds. I was going for 30 secs, but I started to hear sizzling/popping noises... I backed the gun off and held it there on "low" for less than a minute, then put away the gun and wrapped the laptop in several layers of thick blankets so that it could cool to room temp as slow as possible. It's also worth noting that I drowned the board with Kester 951 before the reflow, but I'm not sure if that helped. It hadn't helped in the past. After reading this thread, I guess I know why.
2. This is critical - BEND THE SPRINGS on top of the thermal cover/pad that rests on top of the GPU. Bend the springs upward, so that whatever you bolt on top will press downward with maximum force. On my laptop, there is a large cast metal heatsink (for the GPU RAM) that bolts on top. By bending the springs upward, I made the cast metal part push the GPU pad aggressively against the GPU. This is a big part of the permanency of the fix. I don't know whether pushing on the GPU forces out more thermal paste, which closes the gap, which increases heat transfer from the GPU, or whether the force squeezes the GPU package and closes any internal gaps/cracks. Those are both ideas I hadn't thought of until reading this thread. To be honest, my reason for doing it was that I wanted the GPU to be held in place for whenever the solder melted again. After all, the reason for the GPU failure was gravity. When the GPU overheated, it would DE-solder if the laptop was right-side up, and RE-solder if the laptop was upside-down. So I figured the added spring pressure would counter the force of gravity and hold the chip against the board.
3. Since the cast metal heatsink/GPU cover is dangerously close to the bottom of the laptop, I wanted to make sure it never experienced any mechanical shock when the laptop was moved/handled/etc. This fix was easy - I just bought a $20 padded plastic thing that sits on my lap, and my laptop rests on top of it. This proved to be one of my best purchases ever, because now I can bounce my laptop around all day without ever having to worry about the GPU (or other internals) being stressed or compressed in any way. The pad also provides a constant air gap for the fan intake. It also protects my sperm
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
So that's it. Reflow the GPU, bend the springs, and get a base/pad thing. Even a portable kitchen cutting-board would work. I don't know whether it was the springs or the pad that helped the most, but I suspect it was a combination of both. One thing I know for sure is that my previous reflow attempt used the same heat gun, on the same setting, in the same manner (but for only 20 seconds, not 28), and with the same flux, and the repair only worked for maybe a month or two. Btw, I also toyed with all the GPU settings via nVidia's software (e.g. clock speed, frame rate, etc.), but nothing I did affected the GPU temp, so I wouldn't bother with any of that.
Since the fix, the GPU temp has been rock solid. It used to constantly go up and down 30 - 40 degrees, but now it only moves 10 degrees (F). And the fan almost never comes on. Before the fix, the fan would constantly wind up and scream for mercy, but now I never hear it. The only thing that raises GPU temps is watching Youtube vids in full-screen (which I never do). Watching small-sized Youtube vids won't even cause the fan to increase from its idle state.
Hope this info helps someone!
Sincerely,
Your friendly local embedded Microchip engineer turned organic chemist turned couch bum
