Author Topic: WANTED: TENMA 72-465 Multifunction Counter Manual/Service Manual  (Read 9415 times)
Offline ShockTopic starter
Looking for the Tenma 72-465 Multifunction Counter Manual and Service Manual or Schematics. Preferably free, electronic version is fine, please let me know if you can assist or have one.
« Last Edit: May 22, 2020, 10:13:17 am by Shock »
Online Andy Watson
Re: WANTED: TENMA 72-465 Multifunction Counter Manual/Service Manual
« Reply #1 on: May 31, 2015, 09:00:54 pm »
Bears an uncanny resemblance to an Elenco F100
http://www.elenco.com/support/manuals
« Reply #2 on: June 01, 2015, 03:20:12 am »
Looks close doesn't it, thanks for that. There is an extra button on the Tenma 72-465 "LF" thought that was a low pass filter at first but with in/out?
Online Andy Watson
« Reply #3 on: June 01, 2015, 09:41:01 am »
You might have an updated version - the basic design seems to have been around for a long time. I have the F1000 - same case, including the L.F. in/out, but the trigger level is replaced by the prescalar input. Mine was bought as a Maplin "Gold" MF1000. These counter appear in several re-badged brands.
« Reply #4 on: June 01, 2015, 03:58:14 pm »
Do you know what the LF in/out is?
Online Andy Watson
« Reply #5 on: June 01, 2015, 04:52:56 pm »
No :(
I had always assumed that it was a low-frequency filter. I have just removed the case but it is not obvious how the switch is connected - only that it switches input to something else, or not. There is a 0.47uF capacitor in series with the input - I thought the switch might short it out to pass D.C. - but it doesn't beep-out and I can't see where the tracks go.
The circuit board is labelled HC-F1000lf, so it looks like Hung Chang were the actual manufacturers.
Online Andy Watson
« Reply #6 on: June 02, 2015, 10:58:17 pm »
By chance, whilst searching for something else, I found Maplin's original instruction book for the MF1000. All it says about the LF switch is:
Low pass filter
   approx  100kHz, - 3dB
   approx 150kHz, -3db at 20dB ATT
« Reply #7 on: June 03, 2015, 07:05:43 am »
Here is a photo of the controls of a similar TENMA 72-465 to the one I have. Does the Maplin MF1000 have matching controls in that manual, namely LF instead of LPF? If so that might be the manual I need, possible to get a copy of it? Send me a PM if required.
Online Andy Watson
« Reply #8 on: June 03, 2015, 12:19:25 pm »
No, it's not looking good :(
I've attached a scan of the MF1000 operators manual. The front panel is exactly as it appears on page 4, plus the Maplin logo. I believe this is the same model but with the LF and Attn buttons swapped:
http://www.radiomuseum.org/r/hungchang_multifunction_counter_hc_2.html
The PCB in my counter bear the Hung Chang label HC-F1000-LF(6).
I've also attached the Elenco manual for the F1000 - it has the schematic for the model without the LF button. Aside from the LF button it appears to be very similar to my MF1000.
« Reply #9 on: June 03, 2015, 03:20:01 pm »
Thanks for that, seems almost comical it's labelled out/in, hopefully eventually someone will show up with the Tenma manual but in the meantime at least I have something to work with, cheers.
« Reply #10 on: November 12, 2015, 01:51:21 pm »
Necro bump
Still looking for the manual specifically an electronic copy of it.
Offline tonyalbus
    • My Channel
« Reply #11 on: June 02, 2020, 02:17:37 pm »
Thanks!
Helpful, looks like my Dynatek DFC1000 but pcb was labled HC-F1000LF too !
