Hello everybody,
This is my first post, but enjoying the forum for a long time. Hope all goes well.
I've bought a broken DMM YFE YF-3503 in a second hand market planning to repair it. I knew it was broken. The LCD shows digits but not measures.
After I opened it I saw some PCB traces burned out in the rotative knob and also 3 resistors burned out R20, R21, R22 near A/DC converter pin 1 (check photo).
After checking the other components I found out that npn C1959 transistor (next to VR1) was also defective. I also changed the A/DC converter ES5106 (similar to a ICL7106).
My last step is to fix the three burn out resistors. I can't see their values, only part of them. I know that R20 and R21 are 1% resistors (R22 5%) and that R20 digits start with 9 (white) and R21 with 4 (yellow) and 0 (black). R21 goes connected to VR1 (200ohms) so it must be 400ohms or near that.
Could it be possible you have the same multimeter and check their real values? I would appreciate it a lot
Thanks in advance.
balpd
