Hello fellow techies.
I recently bought a Heathkit Capacitor tester it-22.
Noticed weird readings from the eye.
Decided to pull it apart and basically do some voltage tests first.
This transformer in it is a 240v instead of the 125v in the circuit diagram I have posted.
The main concern I have, are the outputs of the transformer are different to the circuit diagram.
1) My transformer output is 14v
Should be 12.6v.
2) Next transformer output is just over 600v.
Should be 540v.
3) Next transformer output is 58v.
Should be 55v.
Wondering if these wrong readings are acceptable for the 1629 tube.
Thanks in advance
