If its own battery is always a source then you do the normal checkup, is there power, how is reset, are signals sane.
Obviously clock must be there also, Y202 first, but maybe radio must be ok also before other things.
U201 should put something on screen, those upper holes should have some activities.
Use the other machine to check how power up happens, maybe pin75 has an initial long down for a wakeup.
If remote display has a wakeup system it must be through the radio.
You can check that also by comparing how the working machine operates.
