Author Topic: rigol firmware brick how to restore?  (Read 2696 times)
Offline ivi_yakTopic starter
« on: December 15, 2017, 10:41:22 pm »
eevblog
Offline Armadillo
Re: rigol firmware brick how to restore?
« Reply #1 on: December 16, 2017, 03:59:35 am »
Ranging from the worse forms of guides/documentation to the poorest of support and so I heard, I actually begin to suspect Rigol is more like marketing house than any true instrument developer / manufacturer. And for that reason, I am not going to buy any Rigol, no matter how cheaply they will have on offer.
The firmware is just like the secret keys and if there are no leaks, no schematics, I am afraid no one here is able to crack it.
I understand your distress. I am sorry, I am not able to help.
You should write to the Manager or CEO of Rigol. But I doubt, like a marketing house or profit entity, they would bothers to help, otherwise they would.
Good Luck.
Edit: I contacted Rigol China, and they are great people there and they quickly provided the solution to the problem of the DG1022.
« Last Edit: December 19, 2017, 04:59:53 am by Armadillo »
Offline martinator
Offline wictor
« Reply #3 on: December 18, 2017, 05:41:31 am »
Hi, could you tell the device type and model number.
« Last Edit: December 18, 2017, 05:45:16 am by wictor »
The following users thanked this post: ivi_yak
Offline Armadillo
« Reply #4 on: December 18, 2017, 06:26:29 am »
Offline Armadillo
« Reply #5 on: December 18, 2017, 06:29:21 am »
Hello
Today I haveonstalled the new firmware
With the message "cal value has been saved, reboot"
After the reboot it boots up but the screen is black
What I have to do?
DG1022
Offline NiaDebesis
« Reply #6 on: December 18, 2017, 08:07:22 am »
Hello
What I have to do?
DG1022
I have called(italian support) and emailed (us support) Rigol 6 days ago, but nothing
Inviato dal mio SM-G920F utilizzando Tapatalk
Offline Armadillo
« Reply #7 on: December 19, 2017, 05:00:28 am »
Hello
What I have to do?
DG1022
Rigol china provided the solution in https://www.eevblog.com/forum/repair/rigol-1022u-doesen't-boot-up/msg1378626/#msg1378626
« Reply #8 on: December 21, 2017, 11:36:06 pm »
hi, thanks for your reply!
How to contact with amazing people of china support?
eevblog
