I'd agree with medvedev, visually double check everything then go for it. 200mA on the 5V rail wouldn't be all that high for such an item. Besides it's a semiconductor circuit so won't behave in a linear V=IxR fashion.
If you have a meter with mA range you could put it in series to monitor the current on that line.
