Author Topic: Monitor won't turn on (solved)  (Read 4592 times)
Offline AndreySTopic starter
« on: June 02, 2018, 09:03:02 am »
I have monitor Belinea 11 19 28, it has same board as ASUS PM17TE (board: 200-100-DA985D).
The problem is that if monitor is connected with vga to the laptop or PC it won't turn on, instead it is repeatedly turn on (for 2-3 sec, green LED lit) and turn off (for 1-2 sec, no LED lit).
If I disconnect VGA cable, it will cycle through some time (2-20 min) and then goes into stand-by mode (orange LED lit). After monitor is in stand-by mode I connect VGA cable and it works.
What more interesting is that if connected with DVI-D cable it works perfectly: at first time turns on.
I replaced almost all cap (including 3 bulged and 10-15 suspects), it didn't resolve the issue.
Monitor's power supply supplies steady 4.85-5.0 Volt (varies when on-off cycling, steady when on).
Boards do not seem damaged.
A guy BassHole in this forum describes same problem.
Did anybody encounter similar issue? Any ideas what to check/replace next in order to fix the monitor?
« Last Edit: June 12, 2018, 10:54:33 am by AndreyS »
Re: Monitor won't turn on
« Reply #1 on: June 02, 2018, 09:14:26 am »
One more thing.
I have two different VGA cables: one has almost all unused pins grounded, another one has not.
With cable one it immediately turns on and stay on, but the screen quickly changes into white. I have to unplug and plug in power cable few times until the screen displays destop (not white backlight).
Both cables are ok, and work perfectly with other monitors.
Monitor is well grounded including pcb and vga ground
« Last Edit: June 02, 2018, 09:21:48 am by AndreyS »
« Reply #2 on: June 02, 2018, 09:29:25 am »
When LVDS cable is disconnected from the board it goes into stand-by mode after plugging in power cord.
Offline Rasz
    • My random blog.
« Reply #3 on: June 02, 2018, 10:33:28 am »
belinea = caps
The following users thanked this post: AndreyS
« Reply #4 on: June 02, 2018, 10:58:50 am »
I replaced almost all caps. Power supply is in working condition 100%.
5V is OK, Brightness level control works, light on/off pin works.
12 V is 14.5 V actually, but is only used for speakers.
Offline Rasz
    • My random blog.
« Reply #5 on: June 02, 2018, 11:20:30 am »
does the laptop/computer see that switch on/off? as in second monitor showing up and being removed constantly?
maybe I2C eprom died?
Offline shakalnokturn
« Reply #6 on: June 02, 2018, 11:00:46 pm »
I do not know of your model but I've had similar and other hard to explain problems on monitors due to corrupt firmwares themselves often due to worn PSUs.
In seeking firmware dumps the Russian fora are the best place to look.
Offline Rasz
    • My random blog.
« Reply #7 on: June 03, 2018, 11:02:26 am »
replacement pcb is ~$5 http://allegro.pl/main-200-100-da985d-nr-3802-i6834294863.html
but 100% working 19 inch monitor itself is worth less
just keep using DVI if that works
edit: it looks like two i2c eproms are in the middle of pcb U4 U5, you could try swapping them with each other (if those are really i2c eproms)
« Last Edit: June 03, 2018, 11:10:07 am by Rasz »
« Reply #8 on: June 07, 2018, 10:59:20 am »
I've found a firmware for my monitor (exect model). Yes, those are real i2c eproms.
Also I decided just in case to solder my external 5 V and 12 V power supplies omitting built-in one. I desoldered transformer. Also I discovered a blob dripped (most likely) from the transformer. See attachments, the blob is located under the transformer, indicating that gravity pulled down that substance from the transformer.
After soldering 12 V and 5 V power supplies, the monitor worked perfectly.
It is still a mistery on why it did work with dvi-d connected to a PC and not with VGA.
If anybody can explain this, I'd be eternally thankful.
As for the monitor's PSU. Is the transormer a culprit of this? My explanation on why 12 V line was 14 V is that 5 V coil's isolative coating melted and it created a short, effectively reducing number of windings. That led to drop in voltage on 5 V line. Since optocoupler is connected to 5 V isolated line, it fedback into IC, which stabilized 5 V line, but also increase 12 V line. Is this explanation plausible?
As for repair, firstly I want to get what a real culprit is. If it is the transformer, I'll just remove that part of a PCB and insert PCB from 12 V PSU and buckconverter to 5 V. Monitor takes 1.3 A @ 12V and 1.3 A @ 5V. Therefore 3A@12V is sufficient.
« Reply #9 on: June 07, 2018, 11:00:26 am »
The point is to use it with my laptop. I cannot use DVI
Offline GreyWoolfe
  • NW0LF
« Reply #10 on: June 07, 2018, 11:30:00 am »
VGA to DVI Adapters are available and cheap.  I use them here.
« Reply #11 on: June 07, 2018, 12:07:09 pm »
the monitor has DVI-D, that means the converter is needed (not just wiring) in order to convert analogue VGA to DVI-D
Offline Rasz
    • My random blog.
« Reply #12 on: June 07, 2018, 07:44:05 pm »
VGA requires 3 very fast ADCs and recovering/locking clock, DVI is pure deserialization, much less power hungry
starting to work after some warm-up time = caps, or maybe intermittent solder joints
« Reply #13 on: June 12, 2018, 09:59:55 am »
I've replaced all electrolytic caps and replaced transformer for similar.
Now it PSU won't start. Some short hissing noises are hearable out of transformer, and voltage on controlling IC is rising to 5V and then suddenly drops to 0V every 0.8 sec.
The voltage on IC is supposed to be 12V at start and 7V at continious working
« Reply #14 on: June 12, 2018, 10:53:02 am »
I fixed it by removing 10 Ohm limiting resistor for IC at AUX coil.
Now it works as supposed: 5.01V, 14.5V and 8.75V on aux (IC)
« Reply #15 on: June 12, 2018, 10:54:01 am »
I suspect AUX coil inductance of replacing transformer is slightly lesser than on original.
Offline yesyesufkurs
Re: Monitor won't turn on (solved)
« Reply #16 on: December 26, 2018, 10:00:54 pm »
Hi, I actually have a question regarding the 200-100-DA985D controller board. The 10 pin power connector on the board that connects to the PSU, could it be possible to power the screen using a Molex cable from my PC PSU? Molex has the following pinout +5V/Gnd/Gnd/+12V, and I only need the LCD panel to turn on, I don't need the speakers or backlight. Could it be possible to wire the +5V cable from the Molex cable to the +5V pin on the controller board and wiring the ground cable to the ground pin next to the +5V pin?
Thanks!
« Reply #17 on: July 18, 2019, 06:37:13 am »
Yes, it will work.
I tested my monitor by connecting it to two power adapters 5v and 12v.
But I would make sure that the current from your molex connector flows only to your lcd circuitry and not back to monitor's power supply. Just break the circuit (desolder some jumpers/diodes). Just in case
« Last Edit: July 18, 2019, 06:41:20 am by AndreyS »
Offline tooki
« Reply #18 on: July 18, 2019, 07:34:08 pm »
Yes, but the chipsets in cheap LCDs do that just fine, and active VGA to DVI/HDMI converters don’t cost very much at all. I used one a few years ago when setting up the conference room projector at work, so that we could have a single HDMI “umbilical cord” snaked through the walls and ceiling, with HDMI, DVI, DisplayPort, and VGA inputs right in the conference table. (The new projector’s WUXGA (1920x1200) resolution got too blurry with the long VGA cable that worked fine at 1024x768, and the VGA->HDMI converter cost a lot less than a high quality VGA cable that could handle WUXGA at the length needed. We had to run HDMI anyway, so using the converter was a no-brainer.)
