Hi guys. Just wanted to share the solution and fix for knowledge: Bose made 2 different battery types for the mini1. The first one (manufactured between 2013 and 2014) has S/N 061xxx. and the second one (manufactured between 2014 and 2016) has S/N 063xxx.
Bose Mini1 Devices made in 2013-2014 uses: 061384, 061385, 061386.
Bose Mini1 Devices made in 2014-2016 uses: 063404, 063287.
Note: for finding the manufactured year and day date, check the serial number on the botom of the device, the eight number will tell you the year, nine, ten and eleven, will tell you the day of the year. For example: xxxxxxx5211xxx means 5 (2015) and 211 (july 1).
As you can see those batteries, externally, physically and even mAh are exactly the same, BUT, internals are different. Yes 063xxx batteries BMS has some kind of DRM protection that won't allow to use a 061 with 063 between them. I gess bose did this for avoiding people changing the batteries and also fighting against chinese counterfeits batteries...
Now, 90% of chinese bateries on the market, are 061xxx version wich means they will ONLY work with first manufactured products (2013-2014). Finding a 063xxx is really really hard and it gets worst when chinese shops on Amazon, ebay, ali, etc, will tell you that you can use a 061 for a 063. Missinformation everywhere unfortunately.
There is a German battery manufacturer that makes a working battery for 063 version as shown here but is expensive (the only one who tells you the truth):
https://www.ebay.com/itm/334459136589?hash=item4ddf516a4d:g:vmwAAOSwmQ9ilZZKSo be careful when you are going to buy a new battery for your product.
Bye!
