naw not really but there are some scorched bits
Mistral MSS8.0INV split system unit just turned off so I checked the indoor unit board and fuse, all ok, so checked outdoor unit and found this..
Its' a 32amp/500v fuse holder and connecting wire that basically shit itself. I'm replacing it with a 32amp/6kv circuit breaker I have in stock. Given it's probably a surge protector from the mains I still wonder why it failed so miserably. The line in is wired back to the fuse box into a separate ceramic fuse. Should it be upgraded as well to prevent a repeat or at least tripping the breaker and is there anything else I should consider to prevent an ongoing problem.
