Hello,
some day ago I have received a Minix Z83-4 (Intel Atom x5 Z8350-based nettop) that should be disposed of.
Reason: Only the red light lights up when a power supply is connected.
Hm, this seems to be a known problem:
https://theminixforum.com/index.php?threads/what-do-the-colors-of-the-led-light-stand-for.21/OK, I have no invoice and the device is out of warranty. And I am curious
So I took the device apart and let my eyeballs do a optical inspection.
Well, an attempt at heat dissipation in the past.
It could be that it was too much heat
After firing up the microburner
(Ersa H25 is too weak) I can see a little bit more.
But nothing what I did not know before by probing with the multimeter.
Let's sketch a little bit:
So U16 seems to be a main power switch controlled by - whatever...
And yes, I replaced it with a wire.
But I'm interested to know: What is the idea behind U16?My first guess: It is the "main power switch" to reduce power consumption during power-off state.
But if U16 opens, the red light comes up (red light = The voltage outputs by the power adapter is not right.). So this can't be the idea behind.
Here a bad photo of the whole PCB top side (if someone is interested in):
Edit: I'm too stupid to use the inline attachments, sorry. I've added the image names.
