Author Topic: Velleman PS603 power supply  (Read 706 times)
Offline vandersTopic starter
« on: August 24, 2023, 10:39:56 am »
Goodafternoon..
Still have a old Velleman PS 603 working powersupply.. but now the amp meter is broken..coil somewhere open / no conduct.
Maybe someone here has an idea / diagram of which type amp meter is inside.. it is one without a shunt, so it could be somewhere in the micro or milliamps range.
If one of the forum members knows, let me know..
Thanks in advance.
Offline Swake
Re: Velleman PS603 power supply
« Reply #1 on: August 24, 2023, 02:25:01 pm »
Use a multimeter to measure it and find out.
When it fits stop using the hammer
« Reply #2 on: August 24, 2023, 08:43:40 pm »
Goodevening..
Thats a good one.. for example 1 at the output with a load, and on the print where the meter is fixed / soldered on the board a second analog one to found out which is the most usefull one..
Try tommorow, tnx
Offline floobydust
« Reply #3 on: August 25, 2023, 03:35:22 am »
Same schematic PS603 (analog meters) or PS613 (digital panel meters).
They are not very strong or well made and need a lot of repairs.
