So I have a Tek DPO4034 that has a broken shaft on the pan/zoom control. The encoder is quite complex and it cannot be repaired. I explored drilling the shaft down the center and using a screw, but it's not built in such a way where that's possible at all.
I'm not sure if this is a custom part or not; I suspect that it is, but I'm hopeful that it's not.
The only marking on it is J07J28. At least I think that it's a zero.
Has anyone ever seen one of these encoders or know who the manufacturer is, or whether it's custom made for Tek?
I'm pretty sure that Tek will not sell the part, and offer only a replacement board for big bucks. These days, I guess they figure if soldering is required, the end loser can't fix it...
Thanks!
