Author Topic: Magix digital satellite receiver, Model: mgx-9800  (Read 1605 times)
Offline repairs onlineTopic starter
« on: February 15, 2015, 07:58:11 am »
This FTA (Free to Air) digital satellite receiver, model mgx-9800 by Magix ( a korean company) on pluging the mains power cord,  has the red led switched on, steady red, the green led, designated as lock, flashing on/off several times and then steady green and the 2 dots, : , in the channel number display, ON.
The power button has no effect.
Checked all power supply output to the main board, all OK.
Any suggestions ...
Offline tautech
Re: Magix digital satellite receiver, Model: mgx-9800
« Reply #1 on: February 15, 2015, 08:08:49 am »
Welcome to the forum.
Maybe it's waiting for you to access the menu and set the LNB up then search for stations.
Is it on the bench or in a "working" installation?
« Reply #2 on: February 15, 2015, 08:27:55 am »
OK/MENU button no effect.  In fact, no AV output signal from the satellite receiver to the TV.  The switch ON/OFF button can neither switch ON or OFF the receiver. Normally, it should display a channel number when switched on.
