Yeah, seems suspicious. Ohm it out, and everything after it. Why did it fail? Perhaps its load failed shorted -- I would hazard a guess, the axial diodes nearby are rectifiers for the nearby small HV electrolytic, and the DIP is a TinySwitch or something like that, and the E-core part is a flyback transformer; and this is all for LV control supply. Of those, the regulator (the DIP) would be the most likely culprit?
