Author Topic: CIC806 is 100% equivalent to ICL7126 ?  (Read 1024 times)
Offline PKTKSTopic starter
  • Country: br
« on: February 24, 2019, 04:49:17 pm »
I am having problems finding the CIC806 datasheet.
CIC has absolutely no end user support with their chipsets.
This old CIC806 chipset may find a use recently
and I need to make sure it is 100% compatible with ICL7126 chips
Any hint or even the datasheet welcome
Thanks
Paul
Offline coromonadalix
Re: CIC806 is 100% equivalent to ICL7126 ?
« Reply #1 on: February 25, 2019, 02:28:21 am »
thakte the 7126 schematics / application note and try to see on your pcb if it match ?
  • Country: br
« Reply #2 on: February 25, 2019, 02:59:54 pm »
Thanx for you reply.
I have even better alternative.
The CIC came from an ancient dead DMM
I have another old crappy based on the 7126 which probably needs
to be replaced. I can try... but  murphy said that checking it first is good ...
The datasheet would clarify some doubts... as I have already heard
that CIC cloned the 7126 without permission... some time later it vanished.
so far no datasheet published... or yet or never available.
I will sleep on that testing bench gig..
I have just ONE salvaged chip
one shot
Paul
« Last Edit: February 25, 2019, 03:02:11 pm by PKTKS »
