I recently purchased a Marconi 2995R Test Set, this is the same as the 2955A but with the Off air receiver.
I was aware of a number of faults when I purchased it and am slowly working through everything.
There is a strange issue with the CRT, where a portion of it has shrunken text, it looks like a linearity issue but making adjustments on the linearity magnet makes no difference.
If I adjust the V position this shrunken part of the picture remains in exactly the same place on the CRT and moving the image up and down shows that.
First port of call was to take the AC1 board out and check the capacitors, I replaced
2x 470uF/16v
1x 1000uF/35v
1x 2200uF/16v
1x 100uF/50v
1x 3.3uF/50v
There are a few other electrolytics there I didn't replace as I don't have that value or they are axial and it would be quite a messy stretch to fit a radial in it's place due to the already long lead on the axials.
All those capacitors that I had removed tested fine with my EVB ESR Meter and my DE-5000 LCR meter.
I checked all the other capacitors and they all seemed fine, even C20 and C16 which are on the one end of the deflection coil, but I will replace these when I order some parts as I don't have them here.
Looking at the waveform from the output of the BU806 and before and after L1, between the pulses there is another small pulse and it's also not flat, it does look like where this extra small pulse is would be in that part of the CRT i'm seeing this issue. But I do not know what a pulse looks like on a perfectly working 2955A/R
I flipped the wires around on the deflection coil and the image flipped upside down as expected, now I was suspecting the deflection coil on the yoke as being the issue, BUT this issue now flips with the image to the bottom of the CRT. So I think I can rule out the CRT/Yoke?
I've attached a picture of the pulse, but this has been shown with the current yoke connected as I do not have any other way of loading this circuit up.
Please ignore the voltage reading on my scope, it just a digital overlay on an analogue scope. It is not indicative of the actual voltage.
As most people who are familiar with this model of test equipment know, the Vertical on these is actually what would be the Horizontal drive on a traditional CRT, Marconi rotated the CRT 90 Degrees.
I'm a bit baffled with this and don't know where to go next, I'm not sure if something is creating a dodgy pulse like the 74LS211, transistors or a passive like a capacitor is acting up at a certain frequency.
Hopefully someone would have come across similar, it's not an issue I've ever encountered on a CRT.
Here is a Youtube link to a video I made of the problem while adjusting the V position to show it is not in the video signal but part of the scan system.
https://youtu.be/EF3Ke5V2aJgPhotos of scope measurements:
https://photos.app.goo.gl/9Zg3SJDJb4zrtgxb6A version of the AC1 schematic attached, this isn't up to date and has some slightly different capacitor values but the circuit is the same, I didn't want to attach the whole service manual as it's huge.
