A big update today.
A member of the Marconi group sent out a replacement LOPT tuning capacitor and LOPT to test.
These arrived with me today and I couldn't wait to get it on the bench.
I tried the capacitor first and there was no change. then I removed my old LOPT and fitted the one that arrived today.
Did a quick sanity check and checked it all over and powered it up.
On power up the H/V was smaller, so I knew straight away the EHT voltage must be higher.
Adjusted the picture up and down with the H position pot, everything looked perfect.
Adjusted the height by adjusting the core in L1, then did the width.
Image is still perfect.
Then adjusted the intensity and WOW it's so much brighter, it's that bright if I turn up it too far I see the whole raster and retrace lines.
Image is so crisp and perfect, no linearity issues at all and I gave the EHT a quick check and I'm getting a reading of 11KV which is
certainly higher than what I saw before.
So it is definitely the LOPT that was at fault, this is great news as I now know exactly what the issue is and that AC1 and the CRT are good.
The only bad news is trying to find a replacement LOPT, that is probably the hardest part.
