Hi, i have a Marconi 2019 signal generator, that blows fuses.. I suspects the mains transformer is faulty. Since i have tested the power supply board right after the mains transformer, using an external supply source. The transformer have 4 seconddary outputs, does any one know which voltages and amp delivery each output should provide? So i can find a replacement?
Best regards
Henrik
