With what I know, I believe that the majority of the hiss is coming from the second preamp stage(for example H404 and H406 on the right channel, I misspoke earlier and said left).
I think this because grounding H414 and H412 with a jumper wire reduces the hiss to nothing, however grounding J406, J408, and J410 does not change the hiss at all. Now the question is what can I do about it, I have seen that replacing carbon film resistors with metal film ones it supposed to reduce induced hiss.
I have ordered a kit of MF resistors as well as an assortment of small transistors just to have on hand, but those will not arrive until Tuesday the 7th.
