I have a Marantz MA700, that has a power issue. I plug the unit it and it powers on, the led on the front of it continuously flashes, which it is not supposed to do.
I have replaced a number of components in the unit that were either out of spec, burnt up, or totally the wrong spec in relation to the service manual.
The oddest thing that I have found is that I get 40+/- Vdc in the majority of locations. I find that the unit also ramps the voltage up I'm not to sure how high it goes, but Ive not wanted to let it go very high as i don't want to cook more pieces.
I have checked all the main caps both by to separate ESR meters, and by a capacitance metre they are all good.
I have checked all of the transistors with a 520B transistor tester (very useful piece of equipment i find)
I have a scope if needed as well.
Any help would be greatly appreciated!
Link for the service manual.
https://www.dropbox.com/s/aewb76qvccv2jk6/hfe_marantz_ma700_service.pdf?dl=0Edit: Change link to the service manual (hopefully better quality)
