Author Topic: Mainboard with No Picture  (Read 2645 times)
Offline 2XTopic starter
  • Country: gr
« on: July 13, 2024, 09:41:59 pm »
I have the motherboard W26361-W84-X-02 where it starts the CPU fan but don't show nothing at all. The problem as I saw is that the CPU don’t take a proper voltage. I measured with oscilloscope the voltages on three CPU inductors and the voltage was mVolt and the processor was a bit warm (not hot like a CPU is).
I measured the pulses from the 15,18,19 pins of ISL6565BCRZ (Multi-Phase PWM Controller) and looks OK. Also, these pulses arrive at the pin 3 of each ISL6612ECB-T (Advanced Synchronous Rectified Buck MOSFET Driver) respectively.
The problem in my opinion is at the output pin 1 that drives the high side mosfet. And in three chips ISL6612ECB-T the pulses are weak and seems like a noise.
I checked for shorts but I didn't find anything and I replace the electrolytic caps.
Also, I tried the below:
I replaced the RAM with a same and functional one (from a same second motherboard that I have).
I replaced the CPU with a same and functional one (from a same second motherboard that I have).
I check the CPU socket for bend pins and all are ok.
I have replace the BIOS chip with a same and functional one (from a same second motherboard that I have).
I have replaced all the caps in the yellow circles with brand new capacitors.
I place a buzzer on the motherboard and no beep even when I remove the RAM.
I tried some PCI tester cards and gave me the below codes:
The one of them show nothing "--".
The second show "0000".
The third show "FF".
As I saw in a "PC Analyzer Users Guide" pdf that I found on the internet:
The "00" means "Code copyng to specific areas is done. Passing control to INT 19h boot loader next.
The "FF" means "Flash ROM programming was succesful. Next restarting the system BIOS."
Do you know what these codes means in practical level?
Datasheets:
https://www.renesas.com/us/en/document/dst/isl6612-isl6613-datasheet (ISL6612, ISL6613)
https://www.mouser.com/datasheet/2/698/intersil_fn9135-1277737.pdf (ISL6565A, ISL6565B)
https://dimm.me/wp-content/uploads/PC_Analyser_Instructions_PCI_ESA_Card_FINAL_OCR-libre.pdf
P.S. I can’t through the motherboard in the bin because it is from an old machine and unfortunately works only with this motherboard with any other similar
« Last Edit: July 15, 2024, 05:45:30 pm by 2X »
Offline indeterminate
Re: Mainboard with No Picture
« Reply #1 on: July 14, 2024, 09:35:54 am »
Connect a speaker to the board
if there is any life in the board you should be able to hear sum beep codes
if no beep codes then look up the voltage requirements for the cpu
and use a meter to find out witch supply is faulty.
The following users thanked this post: 2X
Online coromonadalix
« Reply #2 on: July 14, 2024, 10:42:41 am »
ok   you have posted elsewhwere too i think
and this board is a Fujitsu Siemens FSC D1837-A21 W26361-W84-X-02 ATX Mainboard Sockel/Socket LGA775 Intel 915 chipset,
you should be able to substitue it, unless you have very specialized software and or markers  who will block from working
you may have gone too far changing all the capacitors.. normally you do the ones in the cpu power section, theses fails often
what caps have you put in there,  low esr ones ? standard ones,  high temps ... and the correct orientation ?
have you tried the psu and forced the psu to start,   you have many infos on how to and atx  pinouts ...   voltage on the 4 pins cpu power plug,  and voltages on the main plug ?
https://theretroweb.com/motherboards/s/fujitsu-siemens-d1837
« Last Edit: July 14, 2024, 10:51:54 am by coromonadalix »
  • Country: gr
« Reply #3 on: July 14, 2024, 11:32:38 am »
unfortunately I can't replace it because have very specialized software.
I placed new nichicon and panasonic Low ESR capacitors and I placed them with the right orientation/polarity.
have you tried the psu and forced the psu to start,   you have many infos on how to and atx  pinouts ?
Sorry but I don't now what do you mean with the "tried the psu and forced the psu to start"
This that I did is to jumper the pins "Power ON-OFF" instantaneously and the PSU start ok (I also tried another PSU) and the voltage on the 4 pins cpu power plug is 12V and on ATX connector there is the voltages 3.3V, 5V & 12V and the pins that they should be (I will check a them again and I will post them).
Thanks for your time and your detailed reply.
« Last Edit: July 14, 2024, 11:35:22 am by 2X »
« Reply #4 on: July 14, 2024, 12:57:12 pm »
atx psu's can be forced to start  you need to tie a wire to ground,  check on the web  atx pinouts, normally it's the green wire if i recall. and to help regulations  sometimes, i put a defective hdd just to create some current draw
clear the motherbaord cmos, sometimes it can help, as other wrote,  if you dont get beeps  post codes,  the trouble may be  harder than you think, the cpu section could be dead ...  and sadly  the motherboard is toasted
the post codes are not fully universal, you need the ones for you bios brand   phoenix, award   etc ....
as for specialized software what it is ?    pick and place .. security ...  usb dongle keys,  hardware id's, you can at least say something .. unless from the start  something is fishy ...
you should try to find intel 915G  based chipsets motherboards  ....  some are very cheap
and you talk about a second  motherboard   does it suffer the same problems ?
« Last Edit: July 14, 2024, 01:02:11 pm by coromonadalix »
  • Country: gr
« Reply #5 on: July 14, 2024, 02:08:24 pm »
The machine is a CNC laser router that was made from a company that don't exist anymore (company name atlas... the customer of the machine told me that)
No this motherboard works fine.
The customer of the machine has given me four same motherboards (from same exactly machine models) where all have the same problem (CPU fan spins and no image) except from one motherboard that works perfect.
I will make some more tests and I give you feedback.
Thanks again for your time.
« Reply #6 on: July 14, 2024, 11:41:55 pm »
please post pictures of the pcb's
Offline Psi
« Reply #7 on: July 15, 2024, 01:37:08 am »
did you read the topic?
"Mainboard with No Picture"     :-DD
« Reply #8 on: July 15, 2024, 02:03:59 am »
 :palm:
Offline fzabkar
« Reply #9 on: July 15, 2024, 02:35:07 am »
Your datasheet links are broken.
What voltage do you measure at the REF pin of the ISL6565BCRZ? Are the VID pins all 1s (Vcore regulator switched off)???
« Last Edit: July 15, 2024, 02:51:48 am by fzabkar »
  • Country: gr
« Reply #10 on: July 16, 2024, 06:57:40 pm »
Thanks... I replaced the links.
I measured all the pins from the ISL6565BCR (at the attached image). The ISL6565BCR have ENable signal but but the voltage at REF pin is zero.
Sorry but I didn't understand what do you mean with "Are the VID pins all 1s"
Thanks for your time and the suggestions.
P.S. One thing that I noticed at the faulty mainboard is (with no CPU fan) when I switch ON the PSU I hear a buzzing with a very low volume (like whisper) around the CPU.
Offline fzabkar
« Reply #11 on: July 16, 2024, 07:29:52 pm »
Look at page 14 of the datasheet.
VID4 - VID0, VID12.5 --> 101001 --> Vcore = 1.350V
VID4 - VID0, VID12.5 --> 010101 --> Vcore = 1.600V
This means that the REF voltage should be 1.35V for the working motherboard, and 1.600V for the faulty motherboard. Instead it is 0V. When the Vcore regulator is functioning properly, the feedback voltage (FB) should match the reference voltage (REF).
Is it possible that the REF pin is shorted to ground, perhaps via the bypass capacitor???
Edit:
The datasheet states that the REF output of the DAC has a 1K series resistor. Could it be that the chipset is pulling this pin to ground and disabling the Vcore regulator???
« Last Edit: July 16, 2024, 09:17:14 pm by fzabkar »
  • Country: gr
« Reply #12 on: July 17, 2024, 08:12:23 pm »
Edit:
I check the capacitor in REF pin and it was OK. I measured it in diode mode and it was 0.73V (0.74V in the working mainboard) and the capacitor (desoldered) is 22nF like in the working mainboard. Also, I disconnect completely the capacitor and did't work, I cut the trace before the the via and didn't work again (attached picture - at the image the capacitor is missing because I took the photo when I have desoldered it).
This 1K resistor is connected between REF pin and at the inputs of two amplifiers via two other "voltage multipliers". There is the possibillity internal the chip to have a short? I measured all the pins in diode mode with the multimeter and all the pins show me the same Volt except from the pin 5 (VID12.5) where it shows me 0.65V in all the faulty mainboards and 0.32V in the working one.
Offline fzabkar
« Reply #13 on: July 17, 2024, 08:54:47 pm »
I can't see any alternative other than replacing that IC. It seems like a strange fault, though. :-?
  • Country: gr
« Reply #14 on: August 13, 2024, 09:44:40 pm »
I replaced the ISL6565BCRZ chip but the same thing again and all the voltages at the ISL6565BCRZ pins are the same. It is something that keep the outputs down. Do you beleive that If the problem is from current sense and if I disconnect the resistors that are for Isense (ISL6565BCRZ picture in red circle) maybe will work? Maybe the problem is on the mosfets or the mosfet drivers that are after the ISL6565BCRZ?
According to the block diagram of ISL6565BCRZ if I understand it right... the only stage that can disable the "DYNAMIC VID" is the "SOFT START AND FAULT LOGIC" and this can be triggered via OVP, ENLL and EN pins, so maybe the problem is at these pins somehow? The strange is tha the voltages are the same these pins with the working one mainboard (picture Voltages).
From ISL6565BCRZ  datasheet:
EN - This pin is a threshold-sensitive enable input for the controller. Connecting the 12V supply to EN through an appropriate resistor divider provides a means to synchronize power-up of the controller and the MOSFET driver ICs.
When EN is driven above 1.31V, the ISL6565A, ISL6565B is active depending on status of ENLL, the internal POR, and pending fault states. Driving EN below 1.14V will clear all fault states and prime the ISL6565A, ISL6565B to soft-start when re-enabled.
ENLL - This pin is a logic-level enable input for the controller. When asserted to a logic high, the ISL6565 is active depending on status of EN, the internal POR, VID inputs and pending fault states. Deasserting ENLL will clear all fault states and prime the ISL6565A, ISL6565B to softstart when re-enabled.
OVP - Overvoltage protection pin. This is an open drain device, which can be externally configured with a resistor to control an SCR to shut down the regulator.
  • Country: gr
« Reply #15 on: August 16, 2024, 06:20:15 pm »
I made some more measurements with oscilloscope. I read on the datasheet that "It is important that the driver ICs reach their POR level before the ISL6565A, ISL6565B becomes enabled.", so I measure the VCC of ISL6565B in respect to ISL6613 in the working and faulty matherbord and the only defference that I saw was a spike in the faulty one.
Also, the PGOOD (in the faulty one is zero and in working one is ~5V) can be affect by pins EN, ENLL, POR, or one of the no-CPU VID codes "PGOOD only transitions low when an undervoltage condition is detected or the controller is disabled by a reset from EN, ENLL, POR, or one of the no-CPU VID codes.". I measured also this with oscilloscope but I didn't saw something.
I measure also the I sense pin but I didn't pulse that will declare a short.
What do you beleive can stop the phase controller from giving PWM pulses?
Also a weird thing for me is that I use a thermal camera and the CPU has temp around 50Celcius (after 2 mins approximattely)... how the CPU can have a temperature like this without the ISL6565B not working?
  • Country: gr
« Reply #16 on: August 16, 2024, 06:21:20 pm »
The rest images.
  • Country: gr
« Reply #17 on: August 18, 2024, 08:25:11 am »
Does anyone knows if there is a aschematic for this motherboard or at least a schematic diagram for a similar model?
« Last Edit: August 18, 2024, 08:31:32 am by 2X »
  • Country: gr
« Reply #18 on: August 18, 2024, 08:31:52 am »
I thought to make an experiment... to remove the CPU and give with an external power supply the 12 V and the VID voltages (VID4 - VID0, VID12.5 --> 010101 --> Vcore = 1.600V) on the ISL6565B and attach a resistor of 4.7ohm at one of the coils so to check if the ISL6565B  will work. Do you beleive it is worth or will make any further damage on the motherboard?
Offline Haenk
« Reply #19 on: August 18, 2024, 08:51:17 am »
Did you check the solid caps? I noticed you did not replace those. These do have a limited lifespan as well; if in commercial 24/7 use over a decade, you might have reached the end of the lifespan.
Is your software bound to the BIOS? I'm really convinced a whole replacement computer might be the way to go, FSC sold a zillion of computers in Germany, might want to check ebay or kleinanzeigen.de
Offline GGMM
« Reply #20 on: August 18, 2024, 09:06:14 am »
Hello,
here a link on site retroweb for this motherboard
Interesting, I have the same phenomenon on my Atlas 757. That’s what happens on the display. Only 00-FF
Curious to know the solution.
cdt
Offline Haenk
« Reply #21 on: August 18, 2024, 09:07:36 am »
This looks like an option to me:
https://www.ebay.de/itm/325351609103
Though not cheap, but cheaper than all the working time already invested. Might need to check for exact mainboard part number...
  • Country: gr
« Reply #22 on: August 18, 2024, 09:07:43 am »
Thanks for your reply... What do you mean by solid caps... you mean the ceramic SMD capacitors (MLCC) or the aluminum ones with red lines around the CPU (those I changed too)?
Because, every problem give you a knew knowledge I don't want to give up.
Offline GGMM
« Reply #23 on: August 18, 2024, 09:12:59 am »
re,
Stupid question, there is no battery on your motherboard picture. Normal?
Because I dig on the side of memory cmos...for my atlas motherboard
 For info only, i think you have put a good battery
cdt
  • Country: gr
« Reply #24 on: August 18, 2024, 09:17:24 am »
re,
cdt
I put a brand new panasonic battery and the same issue. Indeed I have noticed also in some old motheboards that if the CMOS battery is low don't start normally.
