Author Topic: mechanical keyboard pcb repair.  (Read 4435 times)
Offline radishTopic starter
« on: February 15, 2015, 05:27:43 am »
hey guys. i was trying to repair a broken mangled micro usb connector, got startled and my hand slipped and the resulting scratch happened. now im not super fimiliar with electronics and to be honest im fairly new. im pretty good at soldering though... just a bit jumpy.
anywho... can anyone help me identify what part i destroyed? on the left is my board cleaned up, the right shows a board with the pcb that isnt damaged.
on a different forum it was suggested that the part has a zero on it meaning its a revision. considering that this is v1.4 of the pcb that makes sense. is there any way to confirm that its just a bridge that i destroyed?
if there is more info i remember i would add it but thats all i can thing off.
here is a scan of the board.
Offline c4757p
  • adieu
Re: mechanical keyboard pcb repair.
« Reply #1 on: February 15, 2015, 05:31:23 am »
Yup, you just knocked a jumper off. The "L1" designator suggests it was supposed to be an inductor/ferrite bead/choke/pick-your-favorite-name to filter that line, and then they decided they didn't need that filter and just put a cheap bridge there. You can use a blob of solder or a bit of wire.
« Reply #2 on: February 15, 2015, 05:37:47 am »
ok thanks for that, let me bridge it and fire it up.
hopefully it wont catch fire.
Offline miguelvp
« Reply #3 on: February 15, 2015, 05:48:57 am »
It's just a zero ohm resistor, so pretty much a jumper.
« Reply #4 on: February 15, 2015, 07:14:08 am »
great success! thanks guys. made a solder bridge and everything worked great!
