Hi everyone,
I pulled out my Mac SE/30 from storage at my parents... Haven't powered it up for almost 15 years. The machine is circa 1989-1991. Turned it on, I can hear the hard drive whirring away, screen on, fan spins. Power seems good but I'm getting what appears to be a common issue on these machines, the dreaded "simasimac" screen:
Thankfully it seems this issue is not unusual and there have been many posts on how to start fixing it. I wanted to share this here on the forum to see if anyone has any other advice that could help. From what I've gathered from the various other postings on this problem (just Google "simasimac") I will need to do the following:
1. take out all RAM/ROM/SIMMS that I can remove and check contacts to make sure they are clean
- is there a contact cleaner I should be using? Am I looking for anything in particular?
2. check all the caps on the board for signs of leakage or corrosion to copper traces
3. replace on-board battery
4. trace paths from main processor to glue chip, and others to make sure all traces have continuity
Some posts have even suggested throwing the main board into a dishwasher to clean it! I'd rather go over it with 99% isopropanol and a Q-tip first before doing that and checking all traces. I'm NOT a fan of putting the board through the dishwasher (and then toaster ovening it)... way too much can go wrong!
A few encouraging points:
1. I'm glad to see the machine power up, doesn't seem to have any power issues.
2. Screen/CRT is good
3. Hard drive sounds like it is trying to load something
4. "Simasimac" (which is a play on Japanese words zebra-striping or simasima) seems to be a common problem with many people having seemingly resolved it by the above steps
Thanks and any advice would be greatly appreciated!
