Author Topic: Looking for this chip 32db 9KHZ-1GHZ (SONOMA 310)  (Read 322 times)
Offline teatimeTopic starter
  • Country: cn
« on: September 14, 2024, 08:08:50 am »
Right now the LNA found output low, the power supply is 15V.
The RF chip suspect defective.
15V via 220ohm provide the working voltage to this RF chip.
The gain it 32db between 9khz to 1GHZ, the gain flatness is +/- 1.5db
But the model is erased by the factory.
Would you help me to find the right model of this RF chip.
Thanks
Offline Manolo Mos
Re: Looking for this chip 32db 9KHZ-1GHZ (SONOMA 310)
« Reply #1 on: September 14, 2024, 04:04:52 pm »
I think there is an error in the schema, output is input and vice versa.
Online coromonadalix
« Reply #2 on: September 14, 2024, 04:11:55 pm »
MAR-3   MAR-6    MAR-8  amplifiers ....
the 32db gain   would tend to be this : MAR-8SM+
https://www.mouser.ca/datasheet/2/1030/MAR_8ASM_2b-1699752.pdf
But the supply voltage ???
« Last Edit: September 14, 2024, 04:15:38 pm by coromonadalix »
  • Country: cn
« Reply #3 on: September 15, 2024, 07:45:34 am »
 I know MAR-8, but the gain only 25db at 1GHZ.
Thanks anyway.
  • Country: cn
« Reply #4 on: September 15, 2024, 07:46:45 am »
You are right, it's my fault, the symbol is incorrect of the amplifier.
