To power this unit all I need is to use is pins 12 and 15 only?
Multi-pin connector pinout:
9 – CAN bus, high
10 – CAN bus, low
11 – Display voltage supply, positive
12 – Voltage supply, negative, terminal 31
13 – Display HV CAN bus low
14 – Display HV CAN bus high
15 – Voltage supply, positive, terminal 30
16 – Anti-theft coding control signal, SAFE, positive
