Author Topic: Looking for a micro usb smd pcb tower connector for repair of TomTom Start 60  (Read 2608 times)
Offline obiwanjacobiTopic starter
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
My TomTom Start 60 has intermittent USB connection resulting in random phantom screen touches and trouble with charging. Driving on bumpy roads causes the unit to become unusable.
The USB connector seated in the connector is very wobbly and I think that is the problem. I have opened my TomTom up and soldered the case/ground leads but that did not do the trick - I think the connector is broken internally.
A somewhat unusual USB connector is used in the TomTom Start 60. I think they call it a tower USB connector for it's receptacle is lift of from the PCB some distance.
I think its very similar to this one:
http://www.ebay.co.uk/itm/tomtom-Parts-NEW-Micro-USB-TOWER-socket-Weison-G3515-39-x-1-Piece-/232022627785
I was just hoping I could get one for less than 10 pounds per piece...  :o
Any ideas?
Thanx.
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
Offline stj
did you try another cable first?
    • Marctronix Blog
No, because it has a specific connector and just wiggling the cable in the TomTom socket also reproduces the problem...
Offline stj
maybe the bad contact is on the cable end.
what's so "custom" about it?
    • Marctronix Blog
(in the meantime) I did try another cable and it does fit -did not expect that- but the problem is still there. Although the original cable might also have problems so I will be replacing that, but a new cable is does not fix it.
Thanx.
Offline jkf1000
The Ebay link you supplied quotes £5.99 and £3.49 shipping to the Netherlands. By my maths that still works out at under the £10 you mentioned.. Karl
