I am sorry I can't exactly identify the IC, but if you do not mind me asking, are you sure you need to?
I mean, this looks like a simple micro-power buck converter controller with integrated diode(s). The roles of all but one pin in your diagram should be
(clockwise, starting top-left in your diagram): boost, ground, feedback, ? (maybe to set the switching frequency??), input voltage, switching output.
I would simply measure the output voltage without the camera plugged in, and if it falls when you plug it in, try to connect a lab power supply (preferably with current limit capability) as the power source instead of this converter, and see what happens.
Identifying these SMD chips is more luck than anything else, so I usually do that as a last resort, not as the first step.
