ever done any repairs of any kind ? these machines are not exactly the easiest to work on.
grab this :
http://www.ko4bb.com/manuals/73.185.120.40/HP_E3632A_Service_Guide_-_Old_version_with_schematics.pdfoff the top of my head (i have repaired many of this series supplies)
if the display does not light there are multiple possibilities
- the display is cracked, vacuum gone and it's over.
- is there a beep during powerup ? if not :
-- the outguard cpu U4 does not come out of reset due to a blown gpib or serial port or missing 5 volt outguard (U10). this guy has to start first
-- the 18 volt rail for the display is missing:check VR1
-- check the outputs of U12 and U16
-- the POR supply has failed (U11) this is a device made by cherry semiconductors. VERY hard to find. if this thing does not start or generate the reset the supply will not start. it can be replaced by a LM2925
-- the display driver U1 or processor U7 is dead. especially if using the older NEC processor this is a problem. if they use the 8051 + TI driver those are fixable but you have to remove the display. supertex makes replacement drivers. SN75518
-- the communication between display and inguard processor is not working . check the lm339 on the display board. they get damaged often.
-- check the flash rom U13. take it out of the socket and put it back in. those sockets develop bad contacts. re-seating the rom solves this.
-- check the series resistors for the -13 volt suplpy on the display board. it's a chain of 4 resistors . they can crack or burn. if they open the 5 volt for the display processor will not work
working on the display board is very tricky as it is referenced to a 17.4 rail. everything "hangs" below so the 5 volt rail is actually -13v from ground ( the display "ground" is -17 volt ). this is due to the filament voltage for the VFDs. these display need to be driven by negative voltages. so HP designed this to "hang" under the main ground. the LM339 do the level shifting from the positive domain to the negative domain.
once communication between inguard (the 80188( and outguard /(8051 on display and another 8051 on GPIB) is established there will be a short beep.
outguard means the chassis ground referenced portion of the system.
inguard is the "floating" supply section including the main processor.
If this all passes the supply should start up with a live display.
oh , check that it is wired for 110 volt.... it wouldn't be the first one set to 220 volt if you are in the US...
