I checked the rail voltages, there were some differences but not sure whether its okay or not. Specified voltage is in brackets.
JL8002B = 14.6V (12V)
JL901A = 14.6V (12V)
JL9501B = 14.8V (9V)
JL9501B = 5.84V (5.9V)
It felt weird that the 9V was way off. But when I checked output voltage regulators downstream for +5VDG, +3.3VDG, +1.8VDG, +5/3.3VMPU, +5/3.3VST, +5VST2, were all spot on. So I guess regulators were still able to handle the higher voltage, or the 9V written on the schematic is wrong.
Also discovered 12/13V connector points turning into 15V on the other end, which is also clearly a mistake.
Discovered I was not getting 12V for the fan rail from D9410, which in turn is also not providing power for all relays on BAPS-0182. I thought it might be bridge rectifier fault, but in circuit tests ok. But I did discover R9410 was 26ohms instead of 0.22, going to replace this but not sure if it will solve the 12V problem. Since the number of parts around that area is limited, should be able to get it sorted out with time.
For dc offset voltage, I had another go after making sure everything was grounded properly in including the chassis, and it is 26mV, and this is not causing the amp to shutoff anymore(yay!).
Also accidentally discovered the op amp board, some were very hot only after 2-3 seconds powered on. My guess was shorted op amps and q1205, q1209 was shorted on pin2&6. q1206 shorted on pin8&2. Going to remove q1205 and hope it really is a bunch of op amps gone wrong causing problems.
