Hi well i was replacing the panel in a siemens qv830 tablet that i bought for $10 but while i tried
to remove the battery pack my knife blade punctured the "protective aluminum/plastic film" and i smelled
a strange odor like metallic/sweet first i didnt take it to serious so i just sealed it up with some tape
nothing bad did happen in hours but i could feel that smell during charging so i took the decition to
remove the battery and trash it.
How do you remove these batteries that are stick to the rear of the display with double sided tape/adhesive
the easiest way? because i removed a battery like the way above a month ago with no problems but i guess
my blade was dull and i just changed the blade to a new one.
It is about the same as this:
http://www.ebay.com/itm/3-7V-6000-mAh-Polymer-replace-Li-Battery-LiPo-For-GPS-PSP-ipod-Tablet-PC-3691155-/181645781560?pt=LH_DefaultDomain_0&hash=item2a4aeeaa38I just feel like it is not advisable to use that pack when you can feel the odor.
