Thanks for your reply.
Can you indicate or point out (on the picture) which is the LVDS cable and the T-con board?
Any tips on how to check if the power supply reaches the T-con board are welcome.
E.g. check for this voltage on these pins.
Thanks!
Matthi.
It looks like you have not very much experience w/that kind of panels..
The TCON is shielded and you need to remove the shield to see board.
The left board is the CCFL inverters and high voltages are present there
DO NOT POKE AROUND CLUELESS...
The reason may be a defective bright controller or just the cables,
TCON is complex board and LVDS signals are also complex to inspect..
Paul
