Author Topic: Coherent compex 200  (Read 560 times)
Offline hitecelecTopic starter
  • Country: in
Coherent compex 200
« on: March 24, 2021, 01:37:29 pm »
Hi All
Are Laser power supply high voltage modules repairable to component level.
There is a label mentioning vacuum tested check mark on the HV Module . Can this module be opened?
thanks in advance
Anand
Offline SMB784
    • Tequity Surplus
Re: Coherent compex 200
« Reply #1 on: March 24, 2021, 02:03:42 pm »
Hi All
thanks in advance
Anand
A more relevant question is are there schematics available to facilitate the repair.  In general these power supplies are quite simple units, but there is no guarantee that they havent scrubbed the chip IDs or used unsourceable parts, and in my experience Coherent doesn't provide repair manuals or schematics for anything.
Regarding opening the HV module, this seems like a bad practice in general for safety reasons, though I dont know if this particular module is vacuum sealed.
The following users thanked this post: hitecelec
Online perieanuo
« Reply #2 on: March 24, 2021, 03:52:12 pm »
can you restore the vacuum level after repair?
if you do, open it :)
